philfingers
Pictures Of Bulkhead Mods For Mi16 Manifold Clearance
philfingers
I'm going to mod the shell of my car to accept the std Mi16 ex manifold. Does anyone have any pics of this done. There's a black car on DES Developments site which is the kind of thing I'm looking for but need more close up detail.
If anyone can help drop me a PM and I'll reply with my email address or something, unless they#re posted on the web already,
thanks,
Phil
ps I'm not interested in angle plates, modified manifolds etc even tho these are easier options. I want to be able to replace a std manifold if required.
:o sorry couldn't resist!! :ph34r:
Have a look at one of returnofjim's project thread's, i'm sure it's one of his i've seen that's a fairly tidy way of removing & boxing the std bulkhead for clearance. :)
jonnie205
best to start chopping out bulkhead until engine sist there on a std lower mount. bend sheet steel to suit and mig into place, you will have to pulse weld the plate in as sheetmetal bodywork is difficult to weld properly and the bulkhead is a very important part of shell in terms of strength
Thats exactly why I use a reangling plate to fit Mi16s to 205s, everything is then standard and just bolts on, the manifold AND the shell.
You just need an oxy torch, mig welder, angle grinder and some extra mild steel sheet.
Stu
Heres how i did mine mate, i too didnt want to use a modded manifold or plate, its done 1400 miles so far without a hint of bother!
Probably should have painted it up in the right colour mind.. :)
philfingers
My thinking with the angla plates is that whilst it's easy to fit when the motors out, get it all lined up etc I'm thinking it's difficult in situ and you could end up with edges and mismatches to screw up the gas flow. Would be a lot easier tho.
Stu did you remove the heater box to do this? If I have to then it's seats out, cage out, dash out etc etc. Big job.
There was me determined to use a std mainfold and mod the shell. . .. . . . .I'll pass on the lump hammer tho Baz!
I used a QEP plate with two standard gaskets (although Matt @ QEP recommends exhaust paste) to replace a reangled manifold and IMO it was actually easier to fit than a standard manifold on studs due to the allen head bolts tightened using a ball end allen key which passes the manifold pipes better than a socket and extension. In fact its so easy I use allen headed bolts even on standard manifolds now. I didn't notice any difference with the engine afterwards either, it seemed to pull just as well and when I removed it I didn't see any soot marks to indicate a mismatch.
  Quote
You would definitely have to take the dash and heater out to modify the bulkhead.
If you are worried about a mismatch you could fit the angle plate to the cylinder head with it out of the car, and then dowel it in place. That way it can only go back in the same position, and then all you have to do is get the manifold in the right place.
philfingers
Tom, yes dowelling maybe an option. Who else makes the angle (reangle!) plates and what sort of money are they?
Would seem a hell of a lot easier than removing the cage, dash and heater etc!
Swazy
Didn´t have to modify something by using 4-1 exhaust manifold
Batfink
is that the maniflow one?
philfingers
That'll not be easy to fit!
I've gone against eveything I said and bought a PRD angled one!
At least then i don't need to arse around removing the cage, dash, heater, carpets etc etc!
Swazy
This one i bought from tt-turbo matches exactly, i didn´t had to change something on the shell etc
philfingers
I've bought the PRD one but now I have the shell stripped so I'm going to do the bulkhead mods while it's apart. Will post some pics after,
phil
