soap.mactavish
Gti6 Conversion Tips
soap.mactavish
Hi all
I have just got a complete gti6 engine and box to put in my 205
but thinking of using an old 1.6 g/box I have kicking around with it now so I keep a good s/lock
but not sure on the fuelling, would it be a good idea to go down the bike tb rout as
I’m not willing to pay £1500 for Jenvey throttle bodies.
any other ideas?
soap.mactavish
soon to be track tool gti6 sleeper!
Edited by soap.mactavish
Richie-Van-GTi
Try and get an unlocked ecu and loom for the 6, even a locked ecu plus unlocking feee will be loads cheaper.
soap.mactavish
got loom and ecu but unsure if its unlocked yet I`ll just have to suck it an see.
boldy205
Im putting twin 45s and Megajolt mappabe ignition on mine, cant beat that roar!!
soap.mactavish
does any one have a list of none 205 gti /306 gti6 bits I will need for the convertion?
i`v done plenty of 309 1.9 whole front ends into 1.6 205 and mi`s swaps in my time but never a gti6.
I`ll try and get a step by step gide on hear as i do it or mayby after if only its a two day`er .
but i`ve had them qwik 10 min jobs before that end up taking all day (I think most of you know what i mean!)
going to start it later this week so we will see...
hodgy
1 re angle the exhaust manifold
2 find a shorter belt so you can by pass the air con pump and power steering
3 find a way of making the 205 water pipe fit the 306 (that little box thing with all the sensors) you can buy an adapter from BBM
4 fit an MI16 1.9 clutch if your wanting to fit a 205 gear box
im still waiting to find out about the wiring as im just getting all my bits together ready to start in a weeks time
soap.mactavish
Thanks for that, I did not know about the water pipe
not 100% till I get it in, but I think the gti-6 exhaust manifold does not need to be reangled .but just the 205 down pipe (easy job) ( the mi does have too, so it clears the bulkhead but gti-6 misses)
Thats impressively optimistic but sadly you have no chance.
Alastairh
Deffinatly. Got it completely wrong.
205 Down pipe needs shortening and the 6 manifold needs to bereangled.
Theres loads of threads on this conversion from the last 12 months. Soon to be as popular as the old Mi16 oil surge debate...
Cameron
Get a Mi bottom end, you won't have to re-angle the mani then. :P
As for the hose, get an ally connector and use half 6 hose and half 205, then you won't have to pay the £extortionate for an adaptor.
soap.mactavish
bugger!! :P
I was banking on not having to mess with that nice work of art that is the gti-6 manifold
where can I get a ally connector from??
i`m not going to try and get a good MI16 bottom end , as most have ether been to the moon and back big ends ground to nothing or too dear.
but i am greatfull for all help and advice
boldy205
If its the conector you have removed in the Pic, Bakers Bushes and Mounts sell them, and allow you to use the Std 205 top hose. i have one on order ATM think, he is stew205 on here.
soap.mactavish
yes mate going to order one off him too (well if I can pm him his box is full) want to know if he has any of the shorter ford top mount as well.
hodgy
ive just got mine off him.i think ive got everything i need to do mine.still waiting on re welding the manifold tho and still trying to find an engine lift.
"there has been loads of threads about gti6 conversions in the last 12months" i was looking for an hour and got bored! so asked someone. id love to fit my webers straight onto the engine but ive read its alot of messing around to get them on webers
