chrisj21
Trouble Starting After Clutch Change
chrisj21
As above changed the clutch and just got her all back together but she wont fire. the only electrics ive removed are the battery leads and gearbox earths.
i've re attached one of the two leads from the negative terminal to the gearbox earth point. is this correct? the other one is also a earth attached to the plate on the wing.
I cant think of anything else i could be. the fuel pump is running and she turns over fine but just wont fire.
any help appreciated.
chris
Richie-Van-GTi
check ign amp is plugged in and lead on dizzy is plugged in. Assuming you have reassambled etc and AFM / ecu temp etc are all plugged in?
chrisj21
Yes have checked all the leads are attached, i did have the afm of and have double checked the connection and also checked the sensors below the dizzy. i'm wondering if ive disturbed some wiring when getting the gearbox back in.
looks like im going to be dismantling it again tomorrow.
Chris
Richie-Van-GTi
Before dismantling check for fuel and spark, chances are its something real simple.
chrisj21
Will do thanks for the advice. im hoping it's just something ive knocked.
Chris
