springs 0 Posted August 31, 2008 when i brought my 205 the side badges were missing but some spares were already purchased but not fitted at the time. whats the best way to stick them back on the car? the old ones were stuck on with double sided sticky pads but it looks like they didnt last overall.. ive got some sticky back velcro available, will this hold it or end up the same as above? thanks Share this post Link to post Share on other sites
swordfish210 20 Posted August 31, 2008 I used double sided tape to stick mine on about 2 years ago and they're still holding strong. I think you need some good quality tape and make sure that both surfaces are spotlesly clean. That should sort it. Share this post Link to post Share on other sites
platty 1 Posted August 31, 2008 Yep, as above. The double sided foam tape is really good. You can get some fairly thin black stuff that sticks like sh!t to a blanket. Share this post Link to post Share on other sites
McDude 33 Posted August 31, 2008 Silicone sealant - works a charm Share this post Link to post Share on other sites
springs 0 Posted August 31, 2008 cool, guess ill have to find some good quality ones then Share this post Link to post Share on other sites
jord294 92 Posted August 31, 2008 there's also stuff called silkaflex iirc Share this post Link to post Share on other sites
cRaig 273 1 Cars Posted August 31, 2008 I stuck mine on with double sided automotive tape and lots of instant silcone gasket stuff. I dont think they'll be coming off for a while Share this post Link to post Share on other sites
sonofsam 5 Posted August 31, 2008 there's also stuff called silkaflex iirc Did mine with this, Sikaflex 291 is the sh*t Share this post Link to post Share on other sites
Baz 421 Posted August 31, 2008 Yep, as above. The double sided foam tape is really good. You can get some fairly thin black stuff that sticks like sh!t to a blanket. Mirror adhesive pads. Some similar stuff isn't quite as good. Make sure you plug/seal the holes that are there usually for the pins though, or you'll get leaks! Share this post Link to post Share on other sites
