ricky123 0 Posted August 30, 2008 Took my 205 out today just for a little run as its been stood for abit while ive been doing a few bits and bobs to it and its kangarooing realy bad, it is realy bad when pulling away in 1st and holding the accelerator at a point does anyone no what could be the problem? theres no air leaks on any of the air pipes etc I did try searching the forum but couldnt realy find much about it any help would be great thanks Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted August 30, 2008 Just sounds like it needs a service and setup to me. Share this post Link to post Share on other sites
djinuk 2 Posted August 30, 2008 a setup ? what variable are there that can need setting up on the 205 gti ? Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted August 30, 2008 Check the fueling and ignition timing. Share this post Link to post Share on other sites
jackherer 543 Posted August 30, 2008 How old is your fuel filter? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 31, 2008 Any moisture build up in the dizzy cap or on the coil wires etc from it being stood? Graham. Share this post Link to post Share on other sites
ricky123 0 Posted August 31, 2008 The timing was out abit so ive adjusted it to as best i can do without a timing gun and it does smell a little bit rich, The fuel filter was on the car when i bought it so could be quiet old, and ive just replaced the dizzy cap and rotar arm along with spark plugs. cheers Share this post Link to post Share on other sites
