Stu 18 Posted August 29, 2008 AS above peeps, Can i run the plate with the hose outlet/inlet at the bottom? or do they have to be at the top? Stu. Share this post Link to post Share on other sites
Garry 1 Posted August 29, 2008 It doesn't matter as the oil system is pressurised. Share this post Link to post Share on other sites
Stu 18 Posted August 29, 2008 I figured as much, just wondered if the flow was better one way or another... Actually, you're just the man Garry, what bore pipe did you use with your install? who did the pipes for you? Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted August 29, 2008 (edited) Your pipe bore depends on the fittings at the sandwich plate and the oil cooler. You've more than likely got 1/2" BSP fittings so just ask for the 1/2" ID pipe to match. Loads of places do them, think auto, demon-tweeks, merlin, rally design, earl's, goodridge. I got mine made up at a local hydraulics place "midland power and motion" Edited August 29, 2008 by oli-pug Share this post Link to post Share on other sites
