Stu
Mocal Oil Cooler Sandwich Plate
Stu
AS above peeps,
Can i run the plate with the hose outlet/inlet at the bottom? or do they have to be at the top?
Stu.
Garry
It doesn't matter as the oil system is pressurised.
Stu
I figured as much, just wondered if the flow was better one way or another...
Actually, you're just the man Garry, what bore pipe did you use with your install? who did the pipes for you?
oli-pug
Your pipe bore depends on the fittings at the sandwich plate and the oil cooler. You've more than likely got 1/2" BSP fittings so just ask for the 1/2" ID pipe to match.
Loads of places do them, think auto, demon-tweeks, merlin, rally design, earl's, goodridge. I got mine made up at a local hydraulics place "midland power and motion"
Edited by oli-pug
