djinuk 2 Posted August 28, 2008 Over the last week my 205 8v 1.9 has drank the last £40 of super i put in it. the car has always has a dead spot when going from 1st to 2nd , and also when held at a certain speed in a low gear the car kangaroos slightly, now i think these 2 problems may have got a little worse also over the last week or so. would i be right in thinking that my airflow meter could be on its last legs , or anybody have any better ideas ? Share this post Link to post Share on other sites
mickie 3 Posted August 28, 2008 i service would be a good idea Share this post Link to post Share on other sites
Anthony 1,003 Posted August 28, 2008 How bad is the economy? Usual suspects are - ECU temp sensor, AFM, TPS, ignition timing, driving style(!) Search should bring up plenty of info, but trying a known good AFM and sticking on a new ECU temp sensor should fix the issue if it was fine previously and you've not changed anything Share this post Link to post Share on other sites
djinuk 2 Posted August 28, 2008 driving style has not changed, im getting about 15/20mpg , no fuel leaks, and never smells of fuel, , yea its only just started, not sure if i can locate a good afm, but how much are the ecu temp sensors. How bad is the economy? Usual suspects are - ECU temp sensor, AFM, TPS, ignition timing, driving style(!) Search should bring up plenty of info, but trying a known good AFM and sticking on a new ECU temp sensor should fix the issue if it was fine previously and you've not changed anything Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted August 29, 2008 £11.75 from GSF. Share this post Link to post Share on other sites
djinuk 2 Posted August 29, 2008 sweet, anybody gota part number, just so im not there for a hour explaining which bit i need Share this post Link to post Share on other sites
