SPGTi
Cometic Headgasket
SPGTi
Is it worth using one of these on a NA Mi16 block / Gti 6 head hybrid engine running std inlet and throttle body ? Also the std thickness for the Cometic Mi16 gasket is 1.3mm whereas I am led to believe a "normal" Pug gasket is 1.45mm. Is this because the Cometic compresses less or will it increase the CR ?
cheers
Steve
I'm sure I've read that an original XU7 gasket is MLS like a cometic one, just a bit cheaper...
dont take my word for it! but may be worth looking into as it's the same bore.
James_R
I've been told by QEP that MLS gaskets and open block don't mix
the gasket on the XU7 I have doens't look MLs, but then 6's some do some don't when it comes to h/gs
taylorspug
All British Gaskets GTI6 head gaskets are MLS, although ive come across a couple of 'normal' style gaskets aswell.
James_R
Guess it's an indicator of wether the heads been off before on them then??
