adamc
Wheel Arch Fitting
adamc
I've just recently put a new front wing on my pug. When i took the plastic arch trim off the old wing i broke most the clips. I have bought some more from peugeot but they are smaller than the predrilled holes in the new wing. So they don't hold the arch on. Anybody got any ideas of how to attach the trim piece to my new wing or have come across this problem before?
Any comments will be much appricated
jord294
you shouldn'y have that problem if you used s genuine peugeot wing.
or have you used a pattern part ?
adamc
its a pattern one, and it had predrilled holes that are just too big
Gentrix
nothing to do with the pattern part, you need those little plastic inserts to stick in the wing, then you push the clips in the inserts.
I see if I can find the part-picture.
andi
Gentrix
you can spot them in this picture - couldn´t find them on the servicebox.
It´s the second part from the bottom - little black insert-thingy.
andi
adamc
andi
the ones i bought are those white clips in the pic, i was told they would be a push fit into the wing but they are too small.
What is the size of the insert? are they for the wing then? where did u get this kit from?
Edited by adamc
Gentrix
you stick the little black one in the wing (from the front not the back) and the white one in the black one - the black one acts as a anchor.
adamc
excellent thanks for that mate, did u get this box for peugeot and i take it they sell the little black things on there own. I will be straight down peugeot tomorrow!
