kate205gti
Tightening Cambelt
kate205gti
on a gti-6.. do i have to lock the timing before i do this??
cheers?
kate205gti
ignore this, i locked it up anyway but the bottom crank pulley is way out of line so thats come off - guessing i need a new one? ive found this guide but could do with even more of an idiots guide - is there one around for a 6 engine please?
stuart.m
Take a look here:
clicky
If you look at the engine section theres a couple of articles there, between them the 6 timing is pretty well dealt with :)
kate205gti
ahh thats brilliant - cheers stuart :D can we have something like that on here for FAQ? :(
how and where do you lock the flywheel though?
i think i need to replace my tensioners (were S16 ones) and cambelt for later 137 tooth ones, the bottom crank pulley doesnt line up although that cambelt timing guide says not to use the timing hole on this :D someone also suggested using an 8v pulley? any definative answer on this please? :)
stuart.m
Flywheel - there is a small hole in the block through which you can put an allen key or something, which goes into a recess in the flywheel and locks it. On that 306 site theres a guide called 'Cambelt DIY change FAQ' - theres a picture of this in there, albeit they are using a chuck key and not an allen key, whatever works.
It is possible to set the timing without the pulley on, by aligning the keyway in the end of the crank with a bolt, theres a picture on that site, easiest way to explain it! BUT - the best method is definetely get a new one, so you know in future it is right. I dont know about the 8v pulleys, although I know there is people sell lighter alloy pulleys for the 6 engine i think? Not sure who though.
The flywheel locking is only onTU car's not XU,
It's common place for them to slip, some have marking arrow's on them other's don;t, Mind if they do slip it will at somepoint break up and fall off, tell tell sign is alt squel as the belt goes slack.
Yes you can use a 8v pulley to line the timing marks up.
boldy205
Miles, you say you can use a 8v pullly to align the timing, will this pully actually fit/is usable on GTi6 engine?? Save buying a new alloy/std pug pully?
kate205gti
ahh thanku miles :lol: muchos helpful :blush:
i was looking at the aluminion crank pulleys - do you do them? or is it worth just getting another normal one from somewhere if the 8v one cant be used permanently?
Alastairh
If your alternator doesn't squeek because of this, just chuck the old one on.
Time the engine up with the 8v pulley as i said earlier, chuck the 6 one on to use, and job done.
