monty69
Speedo Reads Too High
monty69
I fitted a s16 gearbox a while back and i think i fitted the top part of speedo/cable drive from old box(s16 box didnt come with one). What do i need to do to get the speedo to be accurate as its currently reading about 10mph too high at 70mph?
did you fit the speedo drive cog and pinion from the original box?
monty69
If you mean did i open the box up and swap parts then no?
applemobile
Use your new found spedo to impress young girls and mates in the pub.
monty69
i prefer the milfs to young girls :D
vickiw106
you have to mactch the drive gear that sits inside diff housing with the pick up gear and sensor
there are two different ratio's
it will work for a certain amount of time until the gears wear/brake (because of the different ratios.
with the different ratios it will effect the speed on your clocks
my friend has does the same in his rally car.
swopt both drive gear it worked and showed the correct speed
hope this helps
monty69
Great help thanks, so will i need to fit s16 drive or a matching pair of 205 drive pinion and drive?
vickiw106
if it was me i would us the 205 ratio as you then know its the same ratio as whats in the 205 clocks
