monty69 6 Posted August 21, 2008 I fitted a s16 gearbox a while back and i think i fitted the top part of speedo/cable drive from old box(s16 box didnt come with one). What do i need to do to get the speedo to be accurate as its currently reading about 10mph too high at 70mph? Share this post Link to post Share on other sites
welshpug 1,666 Posted August 21, 2008 did you fit the speedo drive cog and pinion from the original box? Share this post Link to post Share on other sites
monty69 6 Posted August 21, 2008 If you mean did i open the box up and swap parts then no? Share this post Link to post Share on other sites
applemobile 0 Posted August 21, 2008 Use your new found spedo to impress young girls and mates in the pub. Share this post Link to post Share on other sites
monty69 6 Posted August 21, 2008 i prefer the milfs to young girls Share this post Link to post Share on other sites
vickiw106 1 Posted August 23, 2008 you have to mactch the drive gear that sits inside diff housing with the pick up gear and sensor there are two different ratio's it will work for a certain amount of time until the gears wear/brake (because of the different ratios. with the different ratios it will effect the speed on your clocks my friend has does the same in his rally car. swopt both drive gear it worked and showed the correct speed hope this helps Share this post Link to post Share on other sites
monty69 6 Posted August 24, 2008 Great help thanks, so will i need to fit s16 drive or a matching pair of 205 drive pinion and drive? Share this post Link to post Share on other sites
vickiw106 1 Posted August 24, 2008 Great help thanks, so will i need to fit s16 drive or a matching pair of 205 drive pinion and drive? if it was me i would us the 205 ratio as you then know its the same ratio as whats in the 205 clocks Share this post Link to post Share on other sites
