Stu
Rear Shocks: I Need Some Recommendations
Stu
Howdy all,
As im nearly finished refurbing my beam im going to do the shocks too as one is leaking. Im running Billies on the front with -40mm springs, the back is a stock 1900 beam and bars, mounted on a Group A kit, lowered 40mm ish.
I use it for trackdays/road use so not after anything fancy or adjustable etc, just a decent upgrade over standard stuff.
I had thought the best/cheapest uprade would be a set of GTI 6 dampers, i need something that is readily available so i can get it finished for the weekend, ready for Curborough :)
Any thoughts? Anyone got anything for sale?
johnnyboy666
ive got gti6 rear dampers and group A mounts and rate them highly, although i was under the impression they were the same as 205 gti ones? i changed mine from base model ones so i cant really make a comparison.
Stu
Coolio, good to get some feedback, thanks bud.
Any more for anymore?
Also, how do 306 D Turbo rear shocks compare to '6 ones? Ive got a set of decent D Turbo shocks to hand, are they an upgrade for the 1900 205 items or would it be a step back?
BuD
If you have them sitting around you may as well give them a try, you will then know first hand
jord294
i've recently changed my rear shoccks to bilstein o/e replacement ones. got them demon tweeks, cost about £70 the pair
totally transformed the rear end
Edited by jord294
