306-turbo-tom
406 2.0l 16v, What Size Flywheel
306-turbo-tom
in the process off building my 2.0l 8v turbo engine to put in my 306 but need to get a 215mm flywheel, is the flywheel out off a 406 2.0l 16v a 215mm, think thats the size i need anyway, and would this be the right 1, it just my mates got a engine down his yard which he said i can have the bits off just cant be bothered to take the box off if it the wrong 1. thanks
215mm :)
make sure it is a 2.0 not a 1.8, as they run a 200mm clutch
Edited by welshpug
S13Nick
mi16 flywheel and clutch u need, or any the same size as that i imagine
306-turbo-tom
yer it is the 2.0l so does that mean its the 215mm, i can get a mi16 flywheel, its just if this 1 will fit then i may as well get this 1 cause its free
306-turbo-tom
it come out off a 406 coupe,
It should be, measure across the clutch plate or clutch surface on the flywheel, it'll be clear if its 200mm or 215mm imo.
Graham.
