Vz_ace
Oil Pressure Xu9j4k
Vz_ace
Hello from Slovenia!
I wonder if 2 bar of engine oil pressure is enough (warm)? if not- what to do?
what about uprated oil spring-is it worth of replacement?
i use shell helix ultra 5w-40. is this ok?
thanks for any usefuul reply.
regards, Vladimir
C_W
Is this at idle / low revs? if so then that's OK.
Vz_ace
yes at low revs. its ok then? ty
regards
Vlado.
RINRIN
on idling 2 bar is OK
On full throttle it should be around 4 to 6 bars
Vz_ace
ok, thanks guys!
v.
Pob
ok, thanks guys!
v.
4-6? I thought there was only 5 bars? Mine runs around 3 when cold and 2ish when warm at around 2000rpm ... But then again the standard gauge is crap
Dan
Guest addi-pusjo
In my gti, the pressure is like 1 bar :)
RINRIN
On mine idling is 2 bars and on full throttle above 4
