Vz_ace 0 Posted August 20, 2008 Hello from Slovenia! I wonder if 2 bar of engine oil pressure is enough (warm)? if not- what to do? what about uprated oil spring-is it worth of replacement? i use shell helix ultra 5w-40. is this ok? thanks for any usefuul reply. regards, Vladimir Share this post Link to post Share on other sites
C_W 3 1 Cars Posted August 21, 2008 Is this at idle / low revs? if so then that's OK. Share this post Link to post Share on other sites
Vz_ace 0 Posted August 21, 2008 Is this at idle / low revs? if so then that's OK. yes at low revs. its ok then? ty regards Vlado. Share this post Link to post Share on other sites
RINRIN 1 Posted August 21, 2008 on idling 2 bar is OK On full throttle it should be around 4 to 6 bars Share this post Link to post Share on other sites
Vz_ace 0 Posted August 21, 2008 ok, thanks guys! v. Share this post Link to post Share on other sites
Pob 1 Posted August 21, 2008 ok, thanks guys! v. 4-6? I thought there was only 5 bars? Mine runs around 3 when cold and 2ish when warm at around 2000rpm ... But then again the standard gauge is crap Dan Share this post Link to post Share on other sites
Guest addi-pusjo Posted August 24, 2008 In my gti, the pressure is like 1 bar Share this post Link to post Share on other sites
RINRIN 1 Posted August 24, 2008 On mine idling is 2 bars and on full throttle above 4 Share this post Link to post Share on other sites
