205johnnyxsi 0 Posted August 20, 2008 Hello my xsi is a pain in the a**s To i was going round a round about and i started to get this knocking and a pull on the wheel happened all the way home, Got home me and a friend discided to have a look ... started off rolling backwards and forwards when it happened you could see both wheels knocking and it started again, Had a further look the passener side cv boot is knackered im thinking about changeing this but dont want the hassel if it could be gearbox and drive shaft Please help what do you lot think it could be, just the cv boot or shaft g/box ? Thanks Johnny Share this post Link to post Share on other sites
shalmaneser 26 Posted August 20, 2008 it'll be the CV itself (not the boot) if it's actually knocking. probably the hub end, that's the more vulnerable end that tends to go first. Either way it'll need replacement, but it's not a big job, although you'll need to drain and replace the gearbox oil if you take the shaft out. Share this post Link to post Share on other sites
