TRYNKEEPUP
Gti6 Brakes
TRYNKEEPUP
Does any one know that a 20.8mm master cylinder will be ok with 306 gti6 brake setup, or will i need bigger m/c
James_R
They'll still work, but most people switch to 23mm 406 non ABS MC's (4port jobs) when going up to these brakes to reduce pedal travel. this is the same size as the 306 gti6 MC the calipers came from.
dazEmad
I find the gti6 brakes ok on the standard mc, theres a bit of pedal travel but i have got used to it.
Bakes100
Also got the standard M/C on mine and it works fine , just have to press it slightly further before it bites.
