wardy18
Driveshafts
wardy18
Does anyone else know what other driveshafts will fit my race 205 currently running 309 hubs and shafts, the car has a much wider track so i need the extra length of the 309 shafts, but what about any other models
like this:
http://cgi.ebay.co.uk/PEUGEOT-306-DIESEL-D...id=p3286.c0.m14
i know 309 shafts are goin to be gettin rare these days so how can i get around this issue going forward?!
thanx
wardy18
looks like ive lost, the 309 shafts i had ordered have been mistakenly sent to wales and will no way get to be by satde and no one else has any or can get them to me by satde, looks like i have to pull out of teh hillclimb monday!!
damn it
If you;ve only got 309 Lower Arm's then the 205 shafts are fine to use
wardy18
ive 3 rose jointed lower arms and ive already had trouble with them car being tracked so wide that the RH outer shaft has come out of the middle cv joint so i dont really wanna risk running 10mm shorter shafts
i do have a LH shaft which looks quite long so im going to try today and remove the shaft/rubber boot from the bit that goes into the gearbox and fit this to th RH shaft and see what happens
i only need the outer shaft, the intermediate bit if fine
timb1046
that ebay item no longer exists.
wardy18
no worries, ive managed to use the LH outer shaft on the RH side and seems to have worked
pdd144c
Are the GTi6 or Xsara VTS ones any good?
Edited by pdd144c
