PVFCpug 6 Posted August 18, 2008 Hi looking at going ignition only ecu on my MI with carbs, single coil with dizzy. Have spotted on flea bay the following would any of them suit. MBE 912V Omex 100 Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted August 18, 2008 Another cheap way is to use a MegaJolt, the MegaJolt unit itself is not expensive even compared to second hand ECU's, to work it needs a 36-1 trigger pattern and then uses Ford EDIS ignition module, crank sensor, coilpack, all obtainable cheaply from the breakers from 1990's Ford Fiestas or Escorts. Share this post Link to post Share on other sites
welshpug 1,675 Posted August 18, 2008 Neal at DES fits OMEX Adrian Share this post Link to post Share on other sites
PVFCpug 6 Posted August 18, 2008 Neal at DES fits OMEX Adrian Thanks for that, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=016 this is the one I is looking at. At the moment set up for Vauxhall but I would have thought that with a Throttle sensor should be OK. Does the MI16 CPS come with the engine or is it in the gearbox? daft question maybe? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 18, 2008 Mi16 cps is fitted in the gearbox above the flywheel 60-2 timing ring. Graham. Share this post Link to post Share on other sites
PVFCpug 6 Posted August 19, 2008 Mi16 cps is fitted in the gearbox above the flywheel 60-2 timing ring. Graham. Graham I am assuming that is on a MI16 gearbox of course. I have a BE1 fitted not sure I have seen anything on there, am I correct in thinking I am going to need a new timing disc. Adrian Share this post Link to post Share on other sites
James_R 3 Posted August 19, 2008 It's part of the flywheel, and some early Be1 boxes don't even have the whole in the casing to accept the sensor. If you have an Mi flywheel you're fine, if you're using an 8v flywheel to save weight then you'll need to swap over. and again if the gearbox is very early you'll need a later casing or whole box to be able to run it. Share this post Link to post Share on other sites
gti-si 0 Posted August 19, 2008 You can modify the original case to accept the CPS as well, bit more dedicated but not that much work. Share this post Link to post Share on other sites
