applemobile 0 Posted August 15, 2008 what do i need to connect my 1.6 altenator to my s16 engine. i take it i need the standard altenator bracket. Will this also accomidate my pas pump? Dosent look like there is much room down there Share this post Link to post Share on other sites
Para 82 2 Cars Posted August 17, 2008 That's the problem, you will have to use an angle grinder to peel some of the metal, just a little bit will be all right to have 1cm of distance. I can give you some pics later today. Mike Share this post Link to post Share on other sites
welshpug 1,677 Posted August 17, 2008 you need an S16 alternator. Share this post Link to post Share on other sites
applemobile 0 Posted August 17, 2008 ahhh well at least now i know im not the first person to encounter this problem. So i should just run the whole setup from teh s16 engine, and 'modify' my engine bay to allow it to fit. Share this post Link to post Share on other sites
Para 82 2 Cars Posted August 18, 2008 Should fit without modification but you will have couple of mm of gap between alternator and the engine bay. It's pretty tight Share this post Link to post Share on other sites
