RINRIN 1 Posted August 14, 2008 Hello, There is a sensor just behind the dist. It gives info about the cold start. I am looking in the Haynes manual diagrams. I cant find it there. Can it be called temperature sender injection unit. Unit 5 in page 201 number 6 in the picture Share this post Link to post Share on other sites
James_m 0 Posted August 14, 2008 Hello, There is a sensor just behind the dist. It gives info about the cold start. I am looking in the Haynes manual diagrams. I cant find it there. Can it be called temperature sender injection unit. Unit 5 in page 201 number 6 in the picture Not sure what its referred to in Haynes, but its probably CTS (coolant temperature sensor) Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 14, 2008 Looking at your pictures above (top one worked as thumbnail if you click on it to get full size image) they are; 1; Vacuum advance capsule. 2. Exhaust manifold (obviously). 3; SAD (supplimentary air devide.). 4; connector to SAD. 5; Water temp sender (either high temp warning lght or guage indication). 6; Coolant temp sender for ecu (the one I suspect you are looking for). 7; Water temp sender (either high temp warning lght or guage indication). 8; Oil temp sender. Graham. Share this post Link to post Share on other sites
RINRIN 1 Posted August 15, 2008 Thanks, This morning it didnt start again and I need to jump start. The car is in repair now. They will check cold start unit Share this post Link to post Share on other sites
