malyso 0 Posted August 12, 2008 There's definately something missing here and letting a proper flood into the car? Any pics of what should be there or better still anyone got on spare? Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted August 12, 2008 isnt that the bit where the blower thingys suck the air from? there shouldbe some sort of filter/cover i think? should be a few quid from the scrappy Share this post Link to post Share on other sites
malyso 0 Posted August 12, 2008 Yeah thats the one, looks like a drying machine connection at the moment... Share this post Link to post Share on other sites
jord294 92 Posted August 12, 2008 yep. your skuttle panel is missing. i have a good condition one here. or as 'johnnyboy666' says. available from the scrappy Share this post Link to post Share on other sites
malyso 0 Posted August 12, 2008 I've taken off the top black panel can't see where another one would go, you sure there's 2? Share this post Link to post Share on other sites
M@tt 77 Posted August 12, 2008 the scuttle panel is supposed to be tucked up under the window seal rubber, make sure when you refit yours you get it poked up underneath it otherwise all rain water will go straight down into the fan Share this post Link to post Share on other sites
Paintguy 0 Posted August 12, 2008 the scuttle panel is supposed to be tucked up under the window seal rubber, make sure when you refit yours you get it poked up underneath it otherwise all rain water will go straight down into the fan Which can be a pig of a job to do... Share this post Link to post Share on other sites
M@tt 77 Posted August 12, 2008 aye, you need a small flat balde screwdriver to help roll the lip out the way and flick it up over tricky bits Share this post Link to post Share on other sites
Arahan 4 Posted August 12, 2008 Does he not mean the big circle shaped hole?? Thats the impression i got when i read it.... Share this post Link to post Share on other sites
malyso 0 Posted August 13, 2008 Yes the big circle shaped hole, there must be a cover or vent that fits over it surely. I don't have a problem witht the scuttle panel that goes right across the top. Share this post Link to post Share on other sites
Arahan 4 Posted August 13, 2008 I thought so! Thought it was me being abit mental for a minute then! Ha! Err, whats normally there, vacuum sunroof thingy I think? Is yours a non sunroof? Or has the sunroof been removed? Share this post Link to post Share on other sites
GLPoomobile 958 Posted August 13, 2008 Nothing is supposed to be there. It's an open hole and has a flap inside which closes when you turn the heater direction control to the closed position. The scuttle panel should have a shielded section on it that stops water ingress from above. Share this post Link to post Share on other sites
James Stewart 1 Posted August 13, 2008 It doesn't look like you are missing anything to me. If there was a cover over the hole how would the blower draw air...? There is a rubber seal which runs round the lip of the hole and looks similar to the tailgate seal. That looks to be in place, but taped up too. It must be taped up for a reason, so you might want to pick a replacement up from a scrappy. With the seal in place and the scuttle fitted as described above it shouldn't leak. James. Share this post Link to post Share on other sites
Jrod 7 Posted August 13, 2008 http://forum.205gtidrivers.com/index.php?s...058&hl=leak Share this post Link to post Share on other sites
Paintguy 0 Posted August 13, 2008 Does he not mean the big circle shaped hole?? Thats the impression i got when i read it.... I got that impression too, and as has been said there isn't anything that covers that hole directly, but the plastic scuttle panel directs water away from that hole if fitted as per Matt's post. Share this post Link to post Share on other sites
Kobayashi 35 2 Cars Posted August 14, 2008 nothing missing here. this is how it looks without all that duct tape: so, just some rubber trim to stop the vent being flooded, but no cover. the white thing is just the shutter. however, it seems like there is an optional filter for this system (i was said that there is earlier one, too, so check yours first), but i have not tried it yet. i'm interested in this, because i find it a bit odd to have leaves or snow blown into my face when driving... "Champion N104", that would be. Share this post Link to post Share on other sites
