Doof
Electrical Gremlins!
Doof
Ok, i've taken my old engine out ready for my new S16 which will be running Megasquirt, this is all going to be wired from scratch so i figured that with no engine related wiring i'd check that all other electrics work....unfortuantley not
Everything is connected apart from a few radiator related plugs, fan switch etc...that shouldn't matter i dont think as all i can see coming back to the main loom is an earth...
I connected a battery up and once i connected all available earths a few things work, the horn, the head lights and umm thats about it.
When putting the hazards on the rear indicators work and the relay clicks but the fronts do nothing.
When using the indicator stalks nothing happens whatsoever, no relay, nothing.
Windscreen wipers / spray doesn't work and i havent touched anything to do with it
Any ideas what i need to be looking for, im totally stumped.
Everything i've mentioned should work without any engine loom stuff right?
Thinking about this i doubt anyone can actually help without seeing it, i bet auto electricians cost a fortune :ph34r:
Lewis
