wardy18
Anyone Recognise This Bolt
wardy18
whilst fidling around with the right hand drive shaft this bolt dropped onto my arm from inside the engine bay and i have no ides where it came from................
its total length is 6cm
thread length 2.3cm
hex head looks about a spanner size 15 or 16
hex head has gone the usual old rusty lumps and isnt anything which i have bolted in when building and fitted the engine as i cleaned every bolt on a wire wheel before using to get rid of any old rust deposits
it has a rather strange "bullet" style like tip to it as you can see from the photo
any ideas where it came from, ive had a quick look and feel but cant find anything?!?!
any ideas would be great before i start pulling the undertray off to investigate
flipperthebushkangaroo
"it has a rather strange "bullet" style like tip to it as you can see from the photo"
Um, what photo? :ph34r:
Or am i being daft?
wardy18
lol sorry i always do that
One of the subframe bolts possibly? From memory they're a 16mm head and about the same length/style you describe.
j_turnell
Look like subframe bolts to me.
Me 3...
wardy18
ooh best be checkin that then, pretty important bolt, probably just come loose with the vibrations
where about on the subframe do you reckon?!
The 2 at the back on each side, that go into the car's body (captives under you feet in footwell!) But judging from where it dropped out, the front mount above the wishbone.
wardy18
ok nice one ill check tomorrow, might go and do a whole spanner check too!!
wardy18
sure enough this bolt was to the front subframe mount above the wishbone
quite concerning because if i had never snapped a driveshaft causing me not to do my final run this may have dropped out never to be seen again while on the last run and i would have never noticed until somethin else went as a result!!
thanx for the help all, saved me hours of searching, very grateful
