IntenseDan 0 Posted August 9, 2008 Okay, go the seat and subframes today, and the subframes have puzzled me... They are for a 205GTI, and Cobra seats so should be a perfect fit! Now i may be doing somethingf wrong here, this is as it stands at the moment: Is that right? If so why have i got this problem...: The hoes dont line up Any ideas? Thanks in advnace! Dan Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 9, 2008 (edited) you got the bars on back to front mate...the bars with two holes in the side goes where you have two bolts by the handbrake Edited August 9, 2008 by GTI6BOY Share this post Link to post Share on other sites
IntenseDan 0 Posted August 9, 2008 Ok, but where do the holes on the other end go? Dan (even with that, the hole on the side still doesnt line up...) Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 9, 2008 (edited) you just use one off the on the door side. You need to fix the L bracket (missing in picture 2)on to the car first then loosly put the bolts in and the tighten it up, it will fit Edited August 9, 2008 by GTI6BOY Share this post Link to post Share on other sites
IntenseDan 0 Posted August 10, 2008 Still no luck Anyone else have any ideas? Dan Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 10, 2008 (edited) Do you have the black L bracket which is part of the car? Edited August 10, 2008 by GTI6BOY Share this post Link to post Share on other sites
bren_1.3 1 Posted August 10, 2008 are you sure they're for a 205? where did you get them from? ive never seen anything like that before. Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 10, 2008 they are for the 205 as i have the same Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 10, 2008 The bit that goes from the front to the back...remove this as its not used Share this post Link to post Share on other sites
IntenseDan 0 Posted August 10, 2008 all the old brackets went with the seats Dan Share this post Link to post Share on other sites
IntenseDan 0 Posted August 13, 2008 all the old brackets went with the seats Dan BUMP is that what i need? the old subframes back? Share this post Link to post Share on other sites
GTI6BOY 29 Posted August 13, 2008 Its difficult to explain without pics. In you second pic the little box section thats part off the car has a black L bracket fixed to it...you need this part first. Share this post Link to post Share on other sites
IntenseDan 0 Posted August 13, 2008 I did that, and it still doesnt fit together, should all parts of the subframe connect together? Feel free to draw a basic picture using paint or something Dan Share this post Link to post Share on other sites
