applemobile 0 Posted August 9, 2008 I have searched teh forum constantly for this but can find anything in specific! every i post i fing just says ''search the forum'' lol. And unfortunately it wont just let you search for S16! Anyway, to the point, im wondering what wiring i will have to do to get my s16 conversion running, i read about thei ''brown multi plug?' is this the only thing that i need to change? and where shoudl it be, most of my loom is made of spade connecters! Any threads that contain this info would be bery well recieved, or is someone could show me a diagram or explain what parts need chopping and changing. Cheers. Share this post Link to post Share on other sites
Ethos 0 Posted August 9, 2008 (edited) Hi mate, these are the brown multiplug connectors you'll need to modify; http://forum.205gtidrivers.com/index.php?a...ost&id=3392 If you follow the engine loom into the bulkhead on the other side will be the ecu cable and these two plugs. I cut mine off the original 8v loom with plenty of slack... see; Then you'll need to join these cables to the cables on your s16 loom. I used some connectors from halfords which are a crimp and then you heat them up to heatshrink around the cable (seem good so far). Edited August 9, 2008 by Ethos Share this post Link to post Share on other sites
applemobile 0 Posted August 9, 2008 thank you my frined, you have saved me a lot of hassle!! Share this post Link to post Share on other sites
Ethos 0 Posted August 9, 2008 No problems, if you need to know anything else i'll try and help. I'm hardly a pro ha... Share this post Link to post Share on other sites
applemobile 0 Posted August 9, 2008 cheers, this was teh only part i been worried about. i pick up the engine tommoro, so work begins then! Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted August 9, 2008 http://forum.205gtidrivers.com/index.php?s...st&p=609438 http://forum.205gtidrivers.com/index.php?s...st&p=831737 Graham. Share this post Link to post Share on other sites
Para 82 2 Cars Posted August 26, 2008 Good luck with , s16 it's a great engine for converson Share this post Link to post Share on other sites
