skanny 0 Posted August 5, 2008 Can anyone confirm if the full system is that same between the 2 cars? If not do you know which bits are the same if any? Thanks Share this post Link to post Share on other sites
welshpug 1,666 Posted August 5, 2008 nope, 309 is longer, downpipe would be compatible IIRC. Share this post Link to post Share on other sites
Baz 421 Posted August 5, 2008 The system itself IS the same, it's the backbox that's longer. Share this post Link to post Share on other sites
jackherer 543 Posted August 5, 2008 The system itself IS the same, it's the backbox that's longer. Its just the tailpipe IIRC, cutting a 309 one down for a 205 should work fine, and conversely you could probably put some sort of tailpipe extension on to fit a 205 exhaust to a 309 although it could look a bit chavvy if you use the wrong tailpipe. Share this post Link to post Share on other sites
Baz 421 Posted August 5, 2008 Cand be used yes, but cutting the 309 BB doesn't really work either as the tail ends up in an odd place on a 205. Share this post Link to post Share on other sites
skanny 0 Posted August 5, 2008 Cand be used yes, but cutting the 309 BB doesn't really work either as the tail ends up in an odd place on a 205. Cheers guys guess i should look out for a 205 specific one then. Regards Colin Share this post Link to post Share on other sites
