djinuk 2 Posted August 4, 2008 I have a electtric sun roof on my 205 that fits the exact same as the sliding one, i have had it apart today and its knackered, and rusty broken un fixable, so because of this i want to replace it, my initial thought is simply riving a sheet of carbon fibre/thin 2 mm steel/alu. but where abouts can i go to get this ? Share this post Link to post Share on other sites
daza4 24 Posted August 4, 2008 Got mine from a local fabricators have a look in yellow pages or something mate for one locally to you. Share this post Link to post Share on other sites
djinuk 2 Posted August 4, 2008 looked a bit more, and i think im going to replace the lot for a vacum sun roof unit, not sure though, ohh the choices, Share this post Link to post Share on other sites
projectpug 0 Posted August 4, 2008 Just replaced mine with alloy sheet this weekend , cost me £34 delivered for the aluminium its 1.5 mm thick and cut to the exact size of the sunroof-let me know if you need to know the sellers name. Also managed to smash the original and get covered in glass and shrards so i would try to avoid breaking it . Share this post Link to post Share on other sites
djinuk 2 Posted August 5, 2008 lol cheers mate, was that to replace the full sliding factory sunroof, , if its cut to the exact size how to you fit it , if you get me, as surely it needs to overlap to allow for the use of rivits ? Share this post Link to post Share on other sites
projectpug 0 Posted August 5, 2008 Yes it is for the 205 sliding sunroof, It does overlap the only thing i had to modify was the corners to make it look like the original. If you need any more info let me know . Thanks Phil Share this post Link to post Share on other sites
timb1046 1 Posted August 5, 2008 have you get the measurements for this, as im looking to get a plate made up. would be good to have some measurements to double check mine against. cheers Tim Share this post Link to post Share on other sites
tonycj 0 Posted August 5, 2008 Hi, was the electric sunroof a vacuum sunroof ? if it was i'd be interested in your electric parts left? as i havent heard of an electric vacuum roof before. Many Thanks, Tony. Share this post Link to post Share on other sites
djinuk 2 Posted August 5, 2008 nah, it looks just like the vacume but dosent seem to work the same (no vacume present) it jst slides in the same way , however using a motor and runners (the runners are rusted to hell and snaped, hence broke, motor etc all works fine though. Share this post Link to post Share on other sites
