allanallen 528 2 Cars Posted August 1, 2008 hi all, my bros mi's suddenly started running on 3 cylinder, no. 2 has no spark but the coil is fine. I put the multimeter across the pins and i'm getting no reading at all, non of the wires seem broken or anything. anyone have any ideas.....ignition module? Also does anyone have the wireing diagram for it (405 2.0 mi16) any help really appreciated because hes driving me insane borrowing my car cheers, al Share this post Link to post Share on other sites
dcc 855 Posted August 1, 2008 hi all, my bros mi's suddenly started running on 3 cylinder, no. 2 has no spark but the coil is fine. I put the multimeter across the pins and i'm getting no reading at all, non of the wires seem broken or anything. anyone have any ideas.....ignition module? Also does anyone have the wireing diagram for it (405 2.0 mi16) any help really appreciated because hes driving me insane borrowing my car cheers, al first off check the rotor arm and cap for the connections, might be as simple as once being worn. Share this post Link to post Share on other sites
Tom Fenton 1,547 Posted August 1, 2008 The 2.0 Mi16 has coilpacks and hence no rotor arm. I'd say it sounds like a classic case of a coilpack u/s. However check the plug on the cylinder thats not firing, I've also seen in the past duff wiring to one injector hence no fuel to one cylinder do the same thing. If the plug is piss wet through then you know it is an ignition problem. I've got a 405 Haynes manual but I don't think it covers the Mi16 engine wiring unfortunately. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 1, 2008 I'd say it sounds like a classic case of a coilpack u/s. However check the plug on the cylinder thats not firing, I've also seen in the past duff wiring to one injector hence no fuel to one cylinder do the same thing. If the plug is piss wet through then you know it is an ignition problem. its defo an ignition problem, theres no power or signal to the coilpack on no. 2, all the others are showing 13 or so volts when running. your right about the manual aswell, what a waste of 20 quid that was Share this post Link to post Share on other sites
welshpug 1,666 Posted August 1, 2008 if you want a manual that covers the management system get a Haynes Workshop manual for the ZX, the red one number 1881 if you haven't got 12v to the coilpack check the large multiplug on the side of the head. coilpack for No2 is fed from pin 12 of the round plug, if you haven't got 12v at the main loom side of the plug its likely to be a break in the wire as there is a single large cable from Pin 1 of the Relay, which splits into 4 before the round plug on the head Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 1, 2008 if you want a manual that covers the management system get a Haynes Workshop manual for the ZX, the red one number 1881 if you haven't got 12v to the coilpack check the large multiplug on the side of the head. coilpack for No2 is fed from pin 12 of the round plug, if you haven't got 12v at the main loom side of the plug its likely to be a break in the wire as there is a single large cable from Pin 1 of the Relay, which splits into 4 before the round plug on the head should there be 12v with just the ignition on or does the engine need to be running? Am i right in saying cylinder no.2, its the second one away from the cambelt end Share this post Link to post Share on other sites
welshpug 1,666 Posted August 1, 2008 (edited) ahh no No1 on a pug is flywheel end pin 13 I think it will be for No3. Should be live to the coilpacks on the second turn (same as the injectors) I think Graham has a PDF of the ZX manual, the actual layout is pretty similar just different wire numbers/colours and position of the ECU and relays. Edited August 1, 2008 by welshpug Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 1, 2008 ahh no No1 on a pug is flywheel end pin 13 I think it will be for No3. how foolish of me cheers for that, i'll give graham a shout Share this post Link to post Share on other sites
calvinhorse 870 Posted August 9, 2008 after my brother had been pulling his hair out for 3 hours he tried swapping the ignition modules over and this cured the problem.. what the hell is that all about? Share this post Link to post Share on other sites
