swordfish210 20 Posted July 31, 2008 (edited) Hi. For a reason that is neither here not there so i'm not going to go in to it , there is a lot of transmission oil on my clutch. Is there any particular way to remove the contamination from the friction plate that anyone on here knows of? Thanks. Mark Edited July 31, 2008 by swordfish210 Share this post Link to post Share on other sites
James_R 3 Posted July 31, 2008 cltuch and brake cleaner usually does the trick, spray and wipe. Share this post Link to post Share on other sites
swordfish210 20 Posted July 31, 2008 that is what i was thinking. I did hear (althought i can't remeber where) that putting a friction plate in a pot of water and boiling it worked wonders? Discuss and feel free to tell me that it's a crock of s**t Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 31, 2008 Coca Cola, proper genuine stuff, boil it up. Share this post Link to post Share on other sites
jord294 94 Posted July 31, 2008 petrol works a treat as well Share this post Link to post Share on other sites
Rom 0 Posted July 31, 2008 If its a lot of oil, i always replace them. Brief exsposure is ok, but if its soemthing like input shaft seal gone, and cluth has been soaked in oil for weeks etc i dont chance it. Once the oil is embedded in to the friction material, it can degrade it. Causing it to slip, or break up. Same as wheel cylinders can knacker brake shoes when they go unnoticed. Thats not to say you wont be able to clean it up, and it will work fine. But i never take the chance. Share this post Link to post Share on other sites
swordfish210 20 Posted July 31, 2008 Well the clutch cost me £130 and has covered about 8 miles.... so i'll probably just clean it Share this post Link to post Share on other sites
Guest 205bandit Posted August 6, 2008 It should be ok cleaned up, not sure if it will be if it has been driven with oil on it though. Share this post Link to post Share on other sites
