McDude 33 Posted July 31, 2008 I did a search, but my problem is quite specific. I have an intermitant starting issue with my Pug - 8v engine. When you turn the key to 'crank' 9 times out of 10 it cranks like a dream. But recently, sometimes it clicks, like a relay click, but then nothing. Flick the key backwards and forwards a few times and eventually it kicks the starter into life. I'm thinking that the problem is a dodgy starter relay, but I'd welcome other suggestions. It starts like a charm, hot and cold most of the time so it has to be a loose connection if it isn't the relay. No other electrical faults. Oh - and where does the relay live if it is that!?!?! Thanks Dudes! Share this post Link to post Share on other sites
welshpug 1,666 Posted July 31, 2008 (edited) There isn't a relay, most common cause of this is the solenoid wire and terminal corroding, and the brown multiplug if fitted. Replacing this wire from the brown plugs under the dash should help a lot. Another cause can be dirty/loose earths, and a poor connection between the battery positive terminal and the shunt box on the slam panel. and if all that doesnt work, and the battery is healthy, fit a later small bodied starter motor from any XU7 or 10 (S16, XSi, gti6, and 1.8 engines etc) Edited July 31, 2008 by welshpug Share this post Link to post Share on other sites
jamiej 0 Posted August 3, 2008 I had this exact same problem with mine but today it totally stopped working. Which is very irritating. So, i have had a look in the trusty haynes and it said a couple of things to check. When i go to crank the car, the headlights do not dim, this apparently indicates that the starter is not getting any power. Where do i start then, the starter is under the inlet so i cant even see the connections on that. Is there anywhere i can/should check. I really need this car working but all i can see under the bonnet is a mass of wires with no real indication what they do or where they go. Is it worth whipping the inlet off and having a better look or is there anywhere else which is more likely to be the cause of the issue. Photographs would be most helpfull. Cheers guys Jamie Share this post Link to post Share on other sites
EnglishRob 0 Posted August 4, 2008 I had this exact problem on my old 1.6. I think the problem was related to the Brown Multi Plug. Try doing a search for Brown Multi Plug and you should find a post telling you where it is. I can't remember exactly as it's going back about 3 years now but I think if I remember correctly it was on the right hand side of the engine bay (when looking at it from the front), possibly under the air flow meter I think. Has about 6 wires going into it and no doubt it's been corroded. When I had the problem and asked about it, some of the guys on here suggested replacement plugs, so it's worth doing a search for Brown Multiplug against my username. Rob Share this post Link to post Share on other sites
