vern 0 Posted July 29, 2008 I am trying to establish the cause of a very bad wobble that starts at about 45mph and gets progressively worse the faster you go. I have had the wheels balanced which improved the problem, there is no play in the lower arms/ ball joint, all I can find is some play in the driveshafts, Drivers side has about 6mm in/out of CV joint movement, passenger side has about 2-3mm up/down movement, is this normal??. Share this post Link to post Share on other sites
swordfish210 20 Posted July 29, 2008 There shouldnt be any. Share this post Link to post Share on other sites
jord294 95 Posted July 29, 2008 have you checked your engine mounts? Share this post Link to post Share on other sites
vern 0 Posted July 29, 2008 No I have not checked the engine mounts but will do tomorrow. Will the movment in the driveshaft cause the wobble I am getting. Share this post Link to post Share on other sites
mitch205gti 1 Posted July 29, 2008 How do you check the engine mounts? Share this post Link to post Share on other sites
jord294 95 Posted July 29, 2008 from experience, a knackered o/s top engine mount will cause problems Share this post Link to post Share on other sites
