munster 0 Posted July 28, 2008 Can anyone suggest a place to get a rear trailing arm? I have found 'Rear Arm' on GSF website p/n T42604 but not sure if this is the right one, or for a GTI. A second hand one would be good if anyone has one? (passanger side) Thanks Share this post Link to post Share on other sites
boombang 2 Posted July 28, 2008 I've got some here spare if you can collect. Have drums on them at the moment off a 1.6. Share this post Link to post Share on other sites
munster 0 Posted July 28, 2008 Ah thanks mate, but i have a 309gti beam on atm. Obviously i cant fit the caliper/disc on a 1.6 arm... can i ? Share this post Link to post Share on other sites
boombang 2 Posted July 28, 2008 Only difference AFAIK is the stub axle length, shorter on the drum models - but happy to be corrected. Share this post Link to post Share on other sites
James Stewart 1 Posted July 28, 2008 Only difference AFAIK is the stub axle length, shorter on the drum models - but happy to be corrected. That is correct. You can swap the stub axle for the 1.9 type. James. Share this post Link to post Share on other sites
welshpug 1,666 Posted July 28, 2008 would also be preferable to fit the arms as a pair as the camber/toe settings vary. Share this post Link to post Share on other sites
boombang 2 Posted July 29, 2008 I got the pair of the ones off that 1.6 beam here like I said - if you don't want them it's no bother, they'll be skipped some point, but if it helps they are yours for nothing. Share this post Link to post Share on other sites
munster 0 Posted July 29, 2008 Thanks chaps. boombang u have a pm. Share this post Link to post Share on other sites
SurGie 54 Posted October 1, 2008 Does any one know if you can you get new ZX arms from citreon still ? Share this post Link to post Share on other sites
Anthony 1,003 Posted October 1, 2008 Does any one know if you can you get new ZX arms from citreon still ? I'm sure you can, but how much they'd be is another matter entirely - certainly won't be cheap, put it that way! Share this post Link to post Share on other sites
