slow_matt
What Is Involved With Changing Gearbox Type
slow_matt
Hi,
I have searched but I cannot find the answer,
What is involved in going from a 1.9 lift reverse gearbox to a normal 1.6.
Currently mine is crunching going into 3rd and 4th and 5th gear is too tall for much use. My commute is 25miles each way on deserted B roads so I use 5 twice each way!
Matt
James_R
You'll need the later type clutch pedal and cable, and later type release bearing (all Be3 stuff)
You coudl put a gearknob top with the over 5th reverse bit on so when mates use the car it doens't confuse them, and can remove the lift up reverse cable.
Then it's just a box swap.
If you're doing that little lot, worth putting a 1.6 flywheel on at the same time it's lighter than the 1.9 item and helps the car go a bit better too.
What exactly do you mean by normal 1.6 gearbox?
If you are staying with the same Be1 (lift up reverse) 1.6 gearbox the Gearbox swap from the articles on the main website will cover the job from start to finish.
If you are looking to wap to the later Be3 gearbox with reverse behind fifth gear then you need to swap the bits as mentioned by James.
slow_matt
Hi Fellas,
Thanks for getting back to me, yup I'd be going from BE1 to BE3.
I've ordered a new clutch kit, release bearing should be in the kit I guess.
I've booked four days off, should be enough!
Matt
slow_matt
Hi,
what's the difference between the clutch pedal please?
Matt
dcc
the be3 clutch pedal has a hook at the end rather than a hole drilled though the end. i was going to dremel the end from my pedal, to match the design of the be3 pedal. decided to buy a new pedal from peugeot, £30.
steve@cornwall
Tried the dremel /hacksaw approach, didn't work. But 30 quid? - don't you have a scrappy near you?
craig f90
I got one for a fiver from the srappy. Dont forget to get a BE3 cable slow_matt. I cant remember how much that was? up to you if you want to risk second hand. But its a waste on a new clutch in my opinion. Be3 gear knobs appear on ebay all of the time.
Its not a bad job to do.
dcc
Tried sevral scrappie's arround here, but no luck.
where would you buy a new clutch cable from?
