kate205gti 4 Posted July 27, 2008 will an mi16 sump will fit a 1999/T Reg 306 cabriolet with the 2.0/16v engine (XU10J4R)? also is the cab tin sumped? cheers Share this post Link to post Share on other sites
welshpug 1,675 Posted July 27, 2008 (edited) it will bolt on yes, I'm unsure how the depth of the sump differs however (do you mean alloy Mi16 or Steel block? and steel or ally sump?) The sump will be alloy on the 10J4R (same sump as the RS) Edited July 27, 2008 by welshpug Share this post Link to post Share on other sites
James_R 3 Posted July 28, 2008 With the spacer plate yes, but it would probabaly leave you worse off than just leaving the original tin one one the cab, not like its going to be a)getting the oil hot, pulling huge cornering speeds. Share this post Link to post Share on other sites
