MrG
Fuel Rail To Injectors
MrG
The rail that feeds the injectors has 2 pipes entering and exiting it at each end, is this a sort of flow and return? i.e a supply to the injectors and a return for excess fuel to the fuel tank? I am contemplating fitting carbs and can see where the fuel pipes go but if one of these is a return to the tank what do I do with this if I fit carbs? Just put a stop end on it and leave it as is?
Andrew
Ditch all the old system and use a Red top pump and 1 feed pipe, This is allot safer than using the std injection pump
MrG
Miles, thanks I'll follow this advice cheers
