smokey 0 Posted July 22, 2008 Hiya guys Been away for a while, but the car is coming along. The shell is de rusted, welded and filled, ready for painting I'm about to fit some new front wings (GTI wings off Ebay) to the car and i just wanted to check i was going to do it right. I've cleaned off all the old sealent on the wings and the shell and they now fit nicely. I've bought some Tiger Seal to seal the wings back to the shell. Is this stuff any good? My plan of action was to put Tiger Seal along the top of the shell where the 4 - 5 bolts are and along the edge of the wheel arch. Then i was going to fix the wing to the car and bolt it in place. Once bolted i was then going to smooth the Tiger Seal which has been squished out and apply more Tiger seal along the the joins to make sure there were no gaps. Once its set i was then going to under seal the inside of the wheel arch and over the Tiger Seal. Does that sound ok or is there a better way? Thanks Share this post Link to post Share on other sites
welshpug 1,666 Posted July 22, 2008 sounds about right, make sure the inside of the wings are painted as well. Share this post Link to post Share on other sites
miamichris 9 Posted July 22, 2008 tiger seal's great stuff, my dad's a bodyworker/sprayer and he only uses it and sikaflex! Share this post Link to post Share on other sites
Paintguy 0 Posted July 23, 2008 Tigerseal is very good stuff, but I'm not sure about using it along the top edge of the wing. Whilst it will do no harm, you'll have one hell of a job on your hands if you ever need to take the wings off again. Share this post Link to post Share on other sites
smokey 0 Posted July 23, 2008 Cool thanks for the replies guys I lined them up last night and i think they look ok. Think i might bolt them on first and check. Will post some pictures up. I think the wings might have been slightly bent when they were taken off the old cars. Another question... I have the bolts for the top of the wings and the clips for the side. But the bolts for the front end and the single bolt in the wheel arch were rusted to nothing. Does anyone have any suggestions on whats best to use? Also on the front of the wings there is a big hole and then 3 small ones for bolts. I cant remember or look (at work) But shouldn't there be a rubber for the bumper? Again if there was mine was knackard. Thanks Share this post Link to post Share on other sites
smokey 0 Posted July 29, 2008 Any help with this guys? Share this post Link to post Share on other sites
James Stewart 1 Posted July 29, 2008 But shouldn't there be a rubber for the bumper? Again if there was mine was knackard. Yes, there should be. Have a look on service box and you can see the fixings in the exploded diagrams. James. Share this post Link to post Share on other sites
smokey 0 Posted July 29, 2008 Yes, there should be. Have a look on service box and you can see the fixings in the exploded diagrams. James. Last time i looked on service box it was in french?! Share this post Link to post Share on other sites
smokey 0 Posted July 29, 2008 Last time i looked on service box it was in french?! Right forget that last comment. Made it english and have signed up. Question is i've looked at the wing diagrams and there is no mention of the rubber section i'm talking about. Can anyone help? Thanks Share this post Link to post Share on other sites
welshpug 1,666 Posted July 29, 2008 they're in the bumper diagrams Share this post Link to post Share on other sites
boombang 2 Posted July 29, 2008 Along the same lines as this thread, what would anyone recommend sealing wings with if you are likely to have to remove again? At the stage soon where the wings will be going onto the rallycar, but being realistic they may have to come off when I bend it - standard silicon sealant do the job? Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 29, 2008 Along the same lines as this thread, what would anyone recommend sealing wings with if you are likely to have to remove again? At the stage soon where the wings will be going onto the rallycar, but being realistic they may have to come off when I bend it - standard silicon sealant do the job? I've had a pair on my red gti for 2 years with no bonding at all - (I'll get around to taking them off to paint and tidy the wheelarch area one day ) Doesn't seem a problem at all. Share this post Link to post Share on other sites
