205toby
Xu10j4rs Gti6 Inlet On Xu9j4?
205toby
Hey guys,
Title says it all I guess! I'm assuming due to differences in port shape and stud layout the answer is not really. What about with adaptation? Has anyone done it? Or when I hear people talking about fitting GTi6 inlets on to Mi's is that the XU10 engined ones?
Cheers and thanks!
Toby
B1ack_Mi16
Inlet will fit fine, just remove locating dowels or drill hole in the manifold, that's it really.
205toby
Sweet! Does it make much of a difference? Surely you would use the GTI6 throttle body: What happens with the TPS?
B1ack_Mi16
I can only guess it's a little better than the standard 1.9 mi16 inlet, but that's just a guess.
About the throttlebody and TPS, you would have to make an adapter plate I think, which will let you put the throttleswitch from the 1.9 engine onto the new throttlebody.
