Equinoxe 0 Posted July 16, 2008 (edited) Sow little info: First of all the whole engine as been rebuild 2-3months ago sow the engine is at his best. Have been running it on the 8v management jettronic with dizzy adaptor. Is has always run fine rev'd nice etc etc But jeah, I want it to do properly, sow I have converted ii to the MI loom, motronic ecu ,ingition,.... Ecu type:Motronicwith knocking sensor without lamba HT-parts are al brand new. It starts fine and idle nice But it won't rev al the way (7300)!!! When flooring it the engine hesitate and he rev just at 3500 sometimes 4000 it wont go higher (similar to launch control effect run-cut-run-cut-run) Thats thus the big big problem don't know anymore what the problem could be as he starts and idle nice ANy help would be appriciated. Sorry for the not exactly perfect english Edited July 16, 2008 by Equinoxe Share this post Link to post Share on other sites
philfingers 5 Posted July 17, 2008 will it rev to the redline when not in gear, or does it not rev above 4k even when standing still. If it does run to 7k then maybe fueling issue. Blocked fuelf filter, injector issue. Basically not even fuel getting through? Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 (edited) will it rev to the redline when not in gear, or does it not rev above 4k even when standing still.If it does run to 7k then maybe fueling issue. Blocked fuelf filter, injector issue. Basically not even fuel getting through? it wont rev on the road neither neutral fuel filter can't be as it was driving good before converting to the MI loom. Injectors were also working fine Edited July 17, 2008 by Equinoxe Share this post Link to post Share on other sites
Simes 248 2 Cars Posted July 17, 2008 Change the ignition amp - for an older Bosch one. I had a misfire on mine, changed the Ignition amp for a ducillier one and it wouldn't rev over 900rpm. Changed it for a brand new Bosch one (which looks different to the old one) and it wouldn't rev over 3500rpm. Fittted an identical 20 year old one and it revs lovely. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 17, 2008 Another vote for ignition amp here as well, I bought a 405 Mi16x4 off ebay some years ago with the same problem, e.g. big misfire about 4k rpm. This one would actually drive through it and clear eventually. Changed all sorts of things as I had another 405 Mi16 at the time, in the end it was the ignition amp that was at fault. Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 what type of bosch is it then? maybe a type nr etc? ve already tried an old ignition amp of a 1.6 but does the same. Share this post Link to post Share on other sites
philfingers 5 Posted July 17, 2008 pretty sure my bosch one was 0227 100 123 Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 pretty sure my bosch one was 0227 100 123 You never gess it but thats the module I ve, And the spare one is alsow the same, and chanching them does take any effect... Sow it must be something else. Started it again to day, running idle lumpy(maybe ecu temp sensor can cause the poor idle and low revs?) Owhje IMPORTANT; I joined the 2 looms myself Share this post Link to post Share on other sites
nick 3 Posted July 17, 2008 Is the AFM flap sticking? Nick Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 Is the AFM flap sticking? Nick already tried the old one of the 1.6 with no results Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 already tried the old one of the 1.6 with no results whats the position of the HT leads on an MI? placed them the same as on the 8v dizzy... does any body got a picture of how they supposed to be Share this post Link to post Share on other sites
welshpug 1,666 Posted July 17, 2008 motronic and Jetronic AFM's are not compatible, have you physically checked if the flap is sticking? what you can do is to remove the black cover, you can then see the needle of the AFM moving. Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 motronic and Jetronic AFM's are not compatible, have you physically checked if the flap is sticking? what you can do is to remove the black cover, you can then see the needle of the AFM moving. the cover has been removed,it moves freely when the enigne is turning... Share this post Link to post Share on other sites
Equinoxe 0 Posted July 17, 2008 whats the position of the HT leads on an MI?placed them the same as on the 8v dizzy... does any body got a picture of how they supposed to be Share this post Link to post Share on other sites
Equinoxe 0 Posted July 19, 2008 meassered at the AFS looks fine, if the tension of the spring is tweaked can this make a difference? Share this post Link to post Share on other sites
Equinoxe 0 Posted July 20, 2008 Problem solved!!! Had to adjust the distance between de flywheel en CAS. Engine revs fine now Share this post Link to post Share on other sites
