stutto
Intermediate Driveshaft Bearing
stutto
As above, I've done a few searches but can't find part numbers or mention of rough prices for a new bearing to go in the lower engine mount.
Help, please.
dealer or bearing supplier only :)
check the condition of the rest of the shaft thoroughly before you go ahead though, in most cases where the bearing has gone there is quite a lot of play in the joints as well so an exchange shaft is more worthwhile.
stutto
Thanks for the reply.
I already have a spare driveshaft - I needed LHS quickly and ended up buying a pair secondhand.
JayCC
I know you already got one but if anyone else is reading, the GKN ones from GSF are very good quality and are only £50. I've had mine on for 12 months with some very lairy driving, and they are still attached :blink:
stutto
I'd probably go for a GSF driveshaft myself next time, bearing was nearly £19 +VAT from Peugeot and I ended up paying the local garage £15 to remove the old bearing and press the new one on.
