Tommer
Rear Beam Refurb Parts List
Tommer
hi gang,
205 failed its mot today, rear beam as suspected so no shock there, i now want to get this sorted asap.
does anyone have a list of parts / bearings etc needed for the rear beam refurb? had a quick search but the 24 pages of results didn't offer my any joy.
cheers in advance.
tommer
Ps. it also failed on:
offside rear fog lamp not working
nearside outer brake hose perished
offisde front suspension arm ball joint excessive play
.36 too high exhaust emissions.
apart from the beam not a bad list at all, though the "offisde front suspension arm ball joint excessive play" means you need a complete wishbone :)
emissions not too bad either, if that's the CO, a bit of fettling or a new Coolant temperature sensor could sort that.
Fog Lamp could be anything from a bulb, to a dodgy switch.
jimistdt
Good point about the Fog Lamp switch, mine almost got a fail on it but the connector had come off the back of the switch on the dash. Reconnected and it was fine.
Tommer
cheers for the link thats well handy!
yeah not to worried about the ball joint, as a simple wishbone swap will sort that, same with the fog light easy enough to make it work and the emiisions just a bit of a mixture adjustment should solve that....
if the rear beam is toast and i am looking at a replacement do you reckon I should go for the 309 replacement, same for the wishbones?
whatya reckon?
cheers for all the comments
tommer
