dino20vt 3 Posted July 15, 2008 Ive got a mate with a 205 with no internet access, and me with only partial access (phone) so im propably asking a question thats been answered a hundred times but the search facility doesnt work on my phone. Basically his 205 has been stood for two years and the o/s trailing arm has seized in the compressed position, any ideas on how to unseize it? Thanks Share this post Link to post Share on other sites
jonnie205 1 Posted July 15, 2008 unbolt beam from car, strip it down, throw tube in the skip, source new tube, rebuild beam, fit beam to car Share this post Link to post Share on other sites
dino20vt 3 Posted July 15, 2008 In a nutshell! WD40 no good then, beam rebuilding costs a fortune, not really viable on his £200 car! Share this post Link to post Share on other sites
welshpug 1,677 Posted July 15, 2008 rebuilt beams don't cost that much, but when compared to a £200 205 even a service is expensive! Share this post Link to post Share on other sites
dino20vt 3 Posted July 15, 2008 welshpug said: rebuilt beams don't cost that much, but when compared to a £200 205 even a service is expensive! Very true, his intention was always to get it back on the road and restore it but his daily driver has just blew its engine and the £200 205 only needs the trailing arm unseizing for 12 months ticket. Is it easy enough to have access to the bearings to unseize? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 15, 2008 No there's no acess unless you drill holes in the tube and fill it with Derv oil, But If it's that bad it's only really ft for scrap and driving around on it, well I hate to think. Share this post Link to post Share on other sites
taylorspug 7 Posted July 15, 2008 Now i have heard that rocking the car in reverse with the handbrake still on will unseize a beam (it was posted on here as it goes). But certainly dont quote me on that, and as someone who rebuilds alot of beams id never do it myself! If its just seized through not being used the tube may well be ok and you could get away with a couple of new trailing arms and bearings. Share this post Link to post Share on other sites
dino20vt 3 Posted July 16, 2008 Miles said: No there's no acess unless you drill holes in the tube and fill it with Derv oil, But If it's that bad it's only really ft for scrap and driving around on it, well I hate to think. When you say tube do you mean the big yellow thing that joins the two sides? When drilling should I drill near the ends? Drilling sounds a bit drastic but could be the last resort but is there anywhere WD40 could penetrate ie where the arms meet the tube? taylorspug said: Now i have heard that rocking the car in reverse with the handbrake still on will unseize a beam (it was posted on here as it goes). But certainly dont quote me on that, and as someone who rebuilds alot of beams id never do it myself! If its just seized through not being used the tube may well be ok and you could get away with a couple of new trailing arms and bearings. Its been sat for two years and had been reconditioned not long before that, I dont know much about rear beams but surely if a bearing isnt worn just dry lubing it should hopefully release it? Share this post Link to post Share on other sites
jackherer 543 Posted July 16, 2008 The dry bearings will probably have rusted into the trailing arm shafts which will leave them pitted. Share this post Link to post Share on other sites
dino20vt 3 Posted July 16, 2008 jackherer said: The dry bearings will probably have rusted into the trailing arm shafts which will leave them pitted. Its only a tempory fix to get it moted, we'll eventully source a used item or refurbish the one one the car Share this post Link to post Share on other sites
philfingers 5 Posted July 17, 2008 I've got beam in bits which is very good, pics here http://s188.photobucket.com/albums/z143/oi...Sale/?start=all images 8601 to 8606, I'm after £80 for it BUT I'm in Alaska for another few weeks yet (it's missing TBs and ARB and few fasteners) If you are going to strip it leave it on the car to start with. Up on stands, use a blowtorch on the torsion bar ends and antiroll bar screws, nuts etc to get some heat into them before trying to get them off. Use a long bar (I use a piece of 20mm box section steel 4 ft long) to knock the arms off from the opposite side. Much easier if it's still on the car. I recently sold a very good 309 beam, rebuilt for £165. You can get something ready to bolt on for a sensible price, probably not worth trying to sort the one you have for that sort of money Phil Share this post Link to post Share on other sites
dino20vt 3 Posted July 17, 2008 philfingers said: I've got beam in bits which is very good, pics here http://s188.photobucket.com/albums/z143/oi...Sale/?start=all images 8601 to 8606, I'm after £80 for it BUT I'm in Alaska for another few weeks yet (it's missing TBs and ARB and few fasteners)If you are going to strip it leave it on the car to start with. Up on stands, use a blowtorch on the torsion bar ends and antiroll bar screws, nuts etc to get some heat into them before trying to get them off. Use a long bar (I use a piece of 20mm box section steel 4 ft long) to knock the arms off from the opposite side. Much easier if it's still on the car. I recently sold a very good 309 beam, rebuilt for £165. You can get something ready to bolt on for a sensible price, probably not worth trying to sort the one you have for that sort of money Phil Sounds like a good price mate, I'll let my mate know. First though to get through the MOT we'll try drenching it in wd40 and reversing with the handbrake on! Share this post Link to post Share on other sites
dino20vt 3 Posted August 19, 2008 Tried the above, wouldnt budge! Drilled the tube, again the wd40 came out and we filled it, still no difference. Whats the easiest, cheapest way to access the bearings? Share this post Link to post Share on other sites
welshpug 1,677 Posted August 19, 2008 strip the trailing arms out, doesnt cost a penny if you have the tools, though it might cost you in parts as its unlikely to go back together if it's seized. Share this post Link to post Share on other sites
gazzamec 0 Posted August 20, 2008 tried to get my seized arm off today aswell, the actual tube from the arm had seized in to the cross tube and my persuasion witha sledge just pulled the arm clean ff the shaft, now its stuck and so am i. gonna pop down the breakers see what theyve got, maybe thats the best thing for you to try too. Share this post Link to post Share on other sites
dino20vt 3 Posted August 20, 2008 My mate tried a scrap yard today, a month ago they had two 309s, today none! (Apparently stardard 309 beams are basically the same other than discs/thinner torsion bar OR anti roll bars not sure which) I think we're more likely to source a cheap standard 309 beam than a 205 gti unit. Share this post Link to post Share on other sites
philfingers 5 Posted August 21, 2008 gazzamec I still have my beam for sale as linked above and home from the states on Friday if you're interested. It's in Halesowen PM me if interested, Phil Share this post Link to post Share on other sites
jonnie205 1 Posted August 21, 2008 i can build you up a beam if you want, have all bits in stock inc gti tubes Share this post Link to post Share on other sites
Tesstuff 222 Posted August 22, 2008 What is your price Johnny ? The price i would want a quote for is, drive down to you, you take this beam off, put a refurbed one on and i drive home after putting currency into your hands Share this post Link to post Share on other sites
