Trick
What Does This Mean?
Trick
What does it indicate when the following happens:
Driving along - put throttle down full, car pulls to the right
left off the gas, car pulls back to the left.
yet it drives straight it holding throttle steady?
Rich_p
Bottom arm bushes gone or balljoints/ track rod ends I'd imagine.
^^^ what he says! Usually bottom arm bushes.
Edited by Baz
large
As above or maybe the bolt is loose. Also check the hole the ball joint goes into isn't oval.
GLPoomobile
It means 2 things:
1 - you don't spend enough time on this forum. Bad boy. You need more dedication to the community :D
2 - you didn't do a search before posting
Had either of the above applied, you'd have seen about 50 gazillion topics on the same subject. Never mind, you live and learn :P:(
Trick
i had my track rod ends changed last year but only done 500 miles on them.
Had an MOT since and advisory said that there was play in the nearside track rod end ball joint - does that mean it wasnt fitted correctly - or a case of not tight enough?
Alastairh
Hello mate. Long time no speak :(
If it had an advisory on the TRE. Id certinly be inclined to look at it. Where ever its fine, or a cheap faulty copy, worn hub, loose bolt etc is something you'll have to jack the car up and have to look at it.
Most commonly its the wishbone bushes. When were they / the whole units changed?
Also checked the hubs for being oval.
20 minutes under the car should show the obvious problem.
Al
Trick
busy at the weekend or one night this week? :)
i work in Kettering now.
Paintguy
It's called torque steer, not something you generally get on a 205 due to the driveshaft design, but the guys above have highlighted the possible causes :)
BusEngineer
Wishbones, get it jacked up and a bar in them, any play in either bushes or balljoint and you have found a problem :)
