Dan Ingram 1 Posted July 14, 2008 The rust has been creeping through on the drivers side rear sill for a while now and I've been meaning to get round to sorting it. I thought it was just a bit of surface rust that I could grind off treat and repaint but on closer inspection its ALOT worse. I gave it a quick run over with the sand blaster to remove the paint and surface rust which revealed some filler so I removed that to find that a bead of black silicone type stuff had been run down the full length of the rear quarter. As far as I'm aware that shouldn't be there, am I right? Inside So.... I'm now left with a gap between the rear quarter and the sill. What do I do with it? I'd like to do it properly so I don't have to re do it in 6 months and bodywork isn't my strong point. I can weld and have pretty much every tool under the sun so doing it myself isn't a problem, I'm just unsure of the proper way to sort it. Any help on this would be greatly appreciated and it could be handy for other members as I know this is a common problem. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 14, 2008 http://forum.205gtidrivers.com/index.php?s...;hl=sill+repair Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 14, 2008 I read through that topic already. Did yours have a bead of sealer running down from the door to the arch? Is the quarter panel not meant to be joined to the sill in some way other than sealer? Also you rear quarter panel seems to be intact apart from the bit at the rear. How do I go about replacing the bit of missing panel thats on show? Share this post Link to post Share on other sites
GLPoomobile 958 Posted July 14, 2008 When you look down inside the rear quarter from inside the car you should see about 3 spot welds holding the wing to the sill. It's then filled with Tigerseal type stuff on the outside. Given how rotten it is, plus the filler, I'm wondering if it's had an impact at some point that has split the panel from the sill. It's obviously been badly repaired at some point no matter what the circumstance. My old 1.9 had been rear ended, and both quarters had been repaired by using a run of white silicone sealer along the inside of the panels. Eventually it gave out and the panels used to creak and come apart, and I could get a finger in between. Even then the rot wasn't that bad though! Share this post Link to post Share on other sites
welshpug 1,666 Posted July 14, 2008 usual cause of rot here is the rear 1/4 seals leaking, but if the sealer was black I don't think it would be original sealer, that tends to be grey or white. got the same repair to do to mine eventually my sill is solid though Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 14, 2008 I was going to post a link to Tom's post, but noticed you'd answered in that one........ so how about this one? http://forum.205gtidrivers.com/index.php?s...=88347&st=0 Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 14, 2008 As far as I can tell it looks like waters been sat in the bottom for a long time and just been left there and at some point someones had a go and bodging it. The tiger seal type stuff must be the black silicone stuff I pulled out. The welds must have rotted away at some point though. At least I know that stuffs meant to be there now, thanks Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2008 I would cut that out, Remove the tank as I bet you'll find the same sort of rust behind that, I car I scraped the other week (205 gti) had a small patch of rust in the same area, I jack it up the the sill well gave way and the car sat still and it reviled allot of rust Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 15, 2008 I had it up on the ramp last week and had a good look round where the tank is and there are no signs of rust at all there, its just this bit of rust on the entire car Share this post Link to post Share on other sites
Fox 3 Posted July 15, 2008 Mine is similar, although hopefully not as bad. It appers to have just split the seam and paintwork, I really need to get it sorted before winter comes around though! What sort is seam sealer is suitable to use? Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 17, 2008 Any decent PU flexible seam sealer will do, the main thing is to ensure the surface is clean and dry before you apply it to make sure it bonds properly to the metalwork. I used some Wurth stuff when I did the repair to the white car but any decent gear from a refinishing factor will do. Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 26, 2008 I've been doing some more poking and scraping today and found more problems . I think the best option to repair the damage I've shown in the pictures is to do something similar to what mickie did (the second link) and use a repair section. The problem is that there is another bit of rot on the same panel but to the back of the car. The rear quarter has been replaced at some point just badly fitted. Is it going to be easier to fit a complete new rear quarter or fit two repair sections? Replacing the panel looks to be quite simple but I could be wrong. Any ideas? Maybe from someone whos fitted a full rear quarter (hint hint tom ) Thanks in advance. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 27, 2008 Pictures will help, but I will say that replacing a entire rear quarter is a LOT I repeat a L-O-T of work and not to be undertaken lightly. Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 27, 2008 Ok ta I'll take some pics tomorrow Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 28, 2008 Heres some pics The sill is solid. There is a bit of surface rust but its not rotten. Just the panel itself that has rotted away. Share this post Link to post Share on other sites
dale205mills 39 7 Cars Posted July 28, 2008 Why do all the h reg 205's have quarter panel problems, I had a 1.9 and you could grab hold of the quarter panel at the bottom and pull it away from the car, bit strange Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 28, 2008 I wouldn't do a quarter just for that. The bit above the rear bumper can easily be repaired by cutting out the bad and then butt welding in some new metal. Same goes for the rotten patch above the sill line. The trailing edge of the sill has gone frilly just like the white car I repaired, I made up a new return and then welded it in place. Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 28, 2008 The rear quarter must be a complete bastard then if thats easier . How long did it take you to do the rear quarter and whats the difficulty with it? Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted July 28, 2008 Days and very. Share this post Link to post Share on other sites
PVFCpug 6 Posted July 29, 2008 Mine is on an F plate and suffered the same problems. Ended up with sills you could put a pencil through. I ended up having new complete sills, and new metal put in from the trim line to the sill on the quarters. Share this post Link to post Share on other sites
craig f90 0 Posted July 29, 2008 I wouldn't do a quarter just for that. The bit above the rear bumper can easily be repaired by cutting out the bad and then butt welding in some new metal. Same goes for the rotten patch above the sill line. The trailing edge of the sill has gone frilly just like the white car I repaired, I made up a new return and then welded it in place. I agree with Tom on this Dan. It really would be simpler and quicker and alot cheaper to repair the areas than fit a rear 1/4 panel. as he says it is a time consuming job (Ive done a few 205s) By the time you've un stitched the panel, cleaned the metal, lined the panel up, bonded, welded, filled, prepped and painted it. A couple or few of full days have flown by and then theres the cost of the panel and materials. Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 29, 2008 Ok thanks, just wanted to make sure it was a complete bastard before I go and try it. Repairing the panel it is then. Cars coming off the road over winter while I get moved in to my new house so I'll get it done then if theres anything left of it Share this post Link to post Share on other sites
