Alan_M 66 1 Cars Posted July 13, 2008 (edited) I'm about to start fitting my full braided hose setup, and can't remember the route the pipe takes around the beam. The braid will be coming from a grommet'd hole near the rear seat belt mounts, so does it go to the bracket bolted to the bottom of the shock or elsewhere? Pics would be a bonus. Also, the grommets I'm using are 20mm (So I can pass the hose and fitting through). There won't be an issue if I fill the gap up with sealer, once the lines are all fitted will there? I also have a bag of 20mm half-blind grommets (blanked), which I could punch a hole through, thread the hose through the grommet before attaching the fitting? Edited July 13, 2008 by Alan_M Share this post Link to post Share on other sites
Paintguy 0 Posted July 13, 2008 Not the best pictures in the world, but they may help a bit: http://s321.photobucket.com/albums/nn385/D...%20GTI/General/ Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted July 13, 2008 Thanks PaintGuy...... One of those pics is perfect! Share this post Link to post Share on other sites
mrswampy 0 Posted July 13, 2008 How ever you route them double check there is notheing for them to get snaggd on or pinchd between. Share this post Link to post Share on other sites
SPGTi 2 Posted July 14, 2008 There was a thread about this with pics from either earlier this year or last year. Might be worth doing a search. Steve Share this post Link to post Share on other sites
SPGTi 2 Posted July 14, 2008 Here, lots of pics. http://forum.205gtidrivers.com/index.php?s...=74756&st=0 Steve Share this post Link to post Share on other sites
