MrG
Which Cage Needs The Dash Cutting?
MrG
Is it OMP or the other make (that escapes me!) that needs part of the dash cutting away?
cazzy93
i have a omp 10 point cage and the dash didnt need cut to fit the cage, hope that helps
Bonzai
safety devices to both. teh challenge cage needs the dash cutting, but its well worth it in my opinion. I found the other type of cage obstructs legrom when getting in and out. I condsider it a compromise, and for me there is no compromising with safety
RonnieG
I fitted a 10 point OMP cage to my 205 a couple of years ago and I'm positive I did not have to alter the dash at all to fit it.
daza4
Its the C13 cage from Safety Devices I think that needs the dash cutting. They do a C12 that is the same just a little shorter and doesnt need the dash cutting.
(I might be wrong on the codes but they are very similar!!)
MrG
cheers guys, I'm going to be looking to buy and instal in the not too distant so this is of help.
Edited by MrG
I would go for one that fits the shell, regardless of what you have to cut!
MrG
agreed, but I'd like to avoid cutting the dash if I can.
Then the cage won't be fitting to the shell IMO.
boldy205
i have a safty devices c12 and no dash cutting is required, just make sure you take the tank out before welding the B pillar mounts!! (Fuel tank is right beneith it!!)
