dirtdog
Heated Seats
dirtdog
i know i could probably buy heated seats..bolt them in and TRY wire them up...(im useless)
but i'm wondering if there is ANYCHANCE what so ever, that i can prehaps buy the like..heating elements from somewhere...stuff them inside the 205 seats and away we go.i'd rather keep the standard seats but, if not i guess i'm changing them :rolleyes: lol
thanks
quite a few high spec 405's had heated seats, but they never worked for long.
dirtdog
:rolleyes: not good news
Ryan
I've been making my own. You just need some thin wire that you can stitch into a pad, then play about with the wire length until you get the amount of heat you want.
daza4
We have used this company in the past with very good results
MOTORMODS HEATED SEATS
give it a try.
Para
HEated seats in 205 was an option or it was just limited production to specific countries like Finland, etc. ??
dirtdog
give it a try.
thanks mate, exactly what i needed. what're they like to wire up?
daza4
Sorry have no idea what they are like to wire up as they always fit ours for us. I am sure they come with all the instructions required. The guys that sell them fit them so they are only a phonecall away and they are very unusual to the point they are extremely helpful if you had a problem!!!
tonycj
If anyone does know how to wire in the heated seats then im interested as i have just got some MI16 405 seats and they are heated, and are getting fitted in the next couple of days.
Tony.
craig f90
Tony.
I'd also be interested in info on this too. Anyone done it?
Ryan
There should be only two wires coming out of the seat. Test them a multimeter to make sure the heating wires aren't broken. Then hook them up to 12v and earth and make sure they heat up properly. There's a temp switch in the seat to stop the wires from burning out, and you should be able to hear it click on and off.
If they're working properly then you just need to hook them up to the ignition with a switch (and a fuse for safety).
