reuben205
Compression Test
reuben205
Can someone clarify what im doing is guna be right.
Remove all spark plugs,
connect compression tester
With full throttle crank engine over for 5-10 secs
Take reading on that cylinder
If low add tea sppon of oil down spark plug and redo test
Do i have to disable ignition circuit,if so how?How about injection system. Sorry did a search and couldnt find it.
reuben205
anybody the car is warming up right now!
MrG
I think thats the way.
this is off another forum but I expect its basically the same?
Note. To carry out a proper test you will need to take three or four pressure readings for each cylinder. Working on a warm engine with a fully charged battery, disable the fuel system, isolate the ignition circuit and remove the spark plugs. Screw the compression tester into the No1 cylinder spark plug hole, spin the engine on full throttle, note and record the pressures. Repeat the test on the remaining cylinders, noting and recording the pressures. Examine the results, wet test if required. Re-fit the spark plugs; connect the HT & LT leads, re-fit fuel pump fuse.
from this site found by browsing
and this site is the same! same thing different site
So if you take out the plugs, does that constitute disabling of the ignition circuit?
Edited by MrG
gti-si
Just unplug the coil and injectors to cut off the ignition/fuel supply
Don't think so, the HT leads will still be sparking away and the injectors will still be fueling
Edited by gti-si
MrG
It didn't sound right whilst I was typing! So how's it going Ruebs?
reuben205
Got
190
195
200
and 50 but the battery went flat on that one, think i was cranking it for two long on the others and the car had been standing for quite a while
Will charge it tonight and retest that cylinder tomoz
Edited by reuben205
